Subscribe Bookmark RSS Feed
Scripting a Gauge R&R Study
paigemiller
Apr 12, 2012
JMP 9
I would like to script a Gauge R&R study involving multiple variables, instead of using the red triangle dropdown menus multiple times from the Chart->Variabliity/Gauge Chart platform.
If you perform the analysis manually, and select from the red triangle dropdown menu item Gauge Studies/Gauge RR, you get two dialog boxes, one which asks if the design is crossed or nested (mine is crossed), and a second dialog box which asks for the Gauge R&R specifications.
When I create a script to perform this task over all Y variables, the first dialog box doesn't appear, but I cannot figure out how to get the 2nd dialog box to not appear, it always appears no matter what I do. If you know how to change the script so that the 2nd dialog box no longer appears, please let me know.
Here is my script:
rezults = Column Dialog(
        title( "Select Columns For Gauge R&R Analysis" ),
        yycol = ColList( "Y, Response",  Mincol( 1 ), DataType( Numeric ) ),
        xxcol = ColList( "X, Factor",  Mincol( 1 ), Modeling Type( Nominal ) ),
        bbycol = ColList( "By"  ));
ylist = rezults["yycol"];
xlist = rezults["xxcol"];
bbylist = rezults["bbycol"];
Variability Chart(
      Y( eval(ylist) ),
      X( eval(xlist) ),
      By ( eval(bbylist) ),
      Model( "Crossed" ),
      Max Iter( 100 ),
      Conv Limit( 0.00000001 ),
      Number Integration Abscissas( 128 ),
      Number Function Evals( 65536 ),
      Analysis Type( Name( "Choose best analysis (EMS REML Bayesian)" ) ),
      Historical Mean( 0 ),
      Historical Sigma( 1 ),
      Process Variation( 0 ),
      Std Dev Chart( 0 ),
      Gauge RR( 6, 0, 0, 0 ),
      Gauge RR Report( 1 )
1 REPLY
mpb
Jun 23, 2011
Something like the following might be helpful. I pulled up the sample dataset "2 factors crossed" and added a column I called MyY with formula random normal mean 0 var 1. The code below stacks the output in one window for all Y columns selected. If you omit the New Window wrapper each Y column would have its own window. The assumption is that each allowable column has values entered for the "Spec Limits" property.
nw = new window("Test Window",
N = NItems(ylist);
//show(ylist,xlist,bbylist);
//show(ylist[1],xlist[1]);
for(i=1,i<=N,i++,
    specs = ylist << get property("Spec Limits");
    usl = specs["USL"];
    lsl = specs["LSL"];
    //show(specs);
    //show(usl);
    //show(lsl);
    vc = Variability Chart(
        Y( ylist),
        X( :Operator, :part# ),
        Model( "Crossed" ),
        Max Iter( 100 ),
        Historical Sigma( 0 ),
        Std Dev Chart( 1 ),
        Gauge RR( 6, usl-lsl, lsl, usl ),
