UEJ
UEJ
Scripting: Save SQL Query Results in Project
Hi, probably a newbie question, but I couldn't find a solution myself: I want to save the table generated by an SQL Query via a JSL into a project. The code is below; labels, etc. were omitted. Unfortunately, the dt seems to be deleted after running the query in background. Is it a timing issue? Thanks for any help.
query = New SQL Query(
	Connection(""),
	QueryName(""),
	Select(Column("", "t1"), ),
	From(Table("", Schema(""), Alias("t1")), )
query << Run Background(OnRunComplete(dt = queryResult));
project = New Project();
project << Save As("");
mmarchandTSI
Re: Scripting: Save SQL Query Results in Project
Running the query in the background causes JMP to not wait for the results before moving on to the next command, so you have to tell it to wait.  I generally define dt as Empty() before the query and then tell JMP to wait until dt is scriptable before moving on.
dt = Empty();
	Connection(""),
	QueryName(""),
While( !Is Scriptable( dt ), Wait( 1 ) );
mmarchandTSI
dt = Empty();
	Connection(""),
	QueryName(""),
If you wish to run the query on background and still perform some actions after the query finishes, you can use PostQueryScript
obj = New SQL Query(Connection("ODBC:DSN=SampleDSN;"), Custom SQL("SELECT c1, c2, c3 FROM my_table;"));
obj << Post Query Script("show( queryResult << Get As Matrix );");
or I think you could also use <<On Run Complete but you need to add more of the script within that (and you might need global scope...).
