dhurw
Scripting Graphs without Graph builder
Good Morning Everyone!  I have been trying to create graphs without the help of graph builder since there is the red drop down button that appears in the window.  This is something I have been tasked to find and have had a big issue in finding the solution.  Basically, I am creating multiple bivariate graphs without the additional graphics such as drop down graphics. Could anyone help in pointing me to an example?
Daryl Hurwitz
Re: Scripting Graphs without Graph builder
Here are a couple of ways you can get what you want.  The first one can use any of the JMP platform graphics and just strip off the graphical portion and paste it into a new window.  The second example creates a new graph from scratch, using the JSL graphics primatives
// Create a Graph Builder that does not have a red triangle
gb = dt << Graph Builder(
	invisible,
	Size( 528, 456 ),
	Variables( X( :weight ), Y( :height ) ),
	Elements( Points( X, Y, Legend( 6 ) ) )
nw = New Window( "Graphs", <<journal, ob = Outline Box("My Graph") );
ob << append( Report( gb )[Picture Box( 1 )] );
Report( gb ) << delete window;
// Create a graph using the JSL graphic primatives
New Window( "Example",
	Graph Box(
		Y Scale( 50, 75 ),
		X Scale( 50, 180 ),
		Marker(
			Marker State( 0 ),
			dt:weight << get values,
			dt:height << get values
ih
Super User (Alumni) ih
You might consider using graph builder to build your charts and then just copying the content to another box.  Here is an example which both uses graph builder and the Graph Box function to construct graphs in a new window without the red triangle.
names default to here(1);
dt = Open( "$Sample_data/Big class.jmp" );
//Make graphs using graph builder
gb1 = Graph Builder(
	Size( 534, 456 ),
	Variables( X( :height ), Y( :weight ) ),
	Elements( Points( X, Y, Legend( 2 ) ), Smoother( X, Y, Legend( 3 ) ) )
//then use the graphs boxes in other windows:
win = New Window( "Plot examples",
	graphbuilder = (gb1 << XPath("//GraphBuilderBox"))[1],
	graphbox = Graph Box(
		Frame Size( 300, 300 ),
		Marker( Marker State( 3 ), :height << get values, :weight << get values );
//close graph builder
wait(0);
gb1 << close window;
//set axis limits for manually created graph:
(graphbox << XPath("//ScaleBox"))[1] << {Min(50), Max(70)};
(graphbox << XPath("//ScaleBox"))[2] << {Min(40), Max(180)};
 Output:
	invisible,
	Size( 528, 456 ),
	Graph Box(
		Y Scale( 50, 75 ),
		X Scale( 50, 180 ),
		Marker(
			Marker State( 0 ),
