jpmontagne
Script to export AIC into new data table
I am comparing AIC results for multiple models in the Fit Parametric Survival platform. At this point, I have a script to run all the models with produces multiple windows, and I and copy/pasting the AIC and other outputs into an excel file one by one. Needless to day, this is a time consuming & wasting process. I'm a novice in JSL, would anybody be able to help me produce an automated process to extract AIC and other information from the multiple report windows and save them into a single data window? The additional information I'm evaluating is parameter convergence, observations used, and # of censored & uncensored values.
Thanks for any help!
Jeff_Perkinson
Re: Script to export AIC into new data table
When you use a By() in a platform launch JMP will return a list of the resulting platforms. Without it, JMP will return a single platform, not in a list.
Since the examples here used By() they needed to index into the list of platforms to reference a specific one for one by group. That's the [1] in:
fmrep1[1][Outlinebox("Parametric ?")][TableBox(1)]<<make combined data table;
You're not using By() in any of your platform launches, so you don't need the [1].
To get all of the tables into a single data table, it would be easiest to start off with all the reports in a single window.
You can do that using New Window() to create your own report window.
dt = Open( "$SAMPLE_DATA\Reliability\Tobit2.jmp" );
myWin = New Window( "My Window",
  fm1 = dt << Fit Model(
  Y( :YLow, :YHigh ),
  Effects( :age, ),
  Personality( Parametric Survival ),
  Distribution( LogNormal ),
  Run( Likelihood Ratio Tests( 1 ) ),
  fm2 = dt << Fit Model(
  Y( :YLow, :YHigh ),
  Effects( :liquidity ),
  fm3 = dt << Fit Model(
  Y( :YLow, :YHigh ),
  Effects( :age, :liquidity ),
combined = myWin[Outline Box( "Parametric ?" )][Table Box( 1 )] << make combined data table;
Notice, that we don't need to get the report object, since we have a reference to the report window, myWin, already.
To get a table similar what you show in your original post you'll need to Split() the table you get from make combined data table.
combined <<Split(
  Split By( :Column 1 ),
  Split( :Column 2 ),
  Remaining Columns( Drop All )
I know that you also want a column to indicate which model the rows represent. Depending on how you're deciding which models to run, it may be easier to keep that list yourself and add a column to the data table with that information yourself.
If you don't know what models you specified, it's possible to extract that from the parametric survival reports but it's not as easy.
-Jeff
-Jeff
11 REPLIES 11
You can interactively produce this result by right-clicking on the table with the AIC value in your report and select Make Combined Data Table.
The scripting equivalent requires sending a message with the same name as the menu command to the display box object that is responsible for presenting the AIC value in the report. Use the following example for this idea:
  • open Big Class
  • launch the Bivariate platform with height versus weight and sex as a grouping variable
  • fit a line in both groups
  • get the reference to the report layer
  • repeatedly subscript the display tree in the report to the level of the first table (e.g., parameter estimates)
  • send the message
dt = Open( "$SAMPLE_DATA/Big Class.JMP" );
biv = dt << Bivariate(
     Y( :height ),
     X( :weight ),
     Fit Line,
     By( :sex )
biv4 = biv << Report;
bivr[1]["Parameter Estimates"][TableBox(1)] << Make Combined Data Table;
jpmontagne
Thanks for your quick reply, Mark!! That was very helpful and educational, although at first it didn't produce the data table until I rewrote the last bit as
Report( biv[1] )["Parameter Estimates"][TableBox(1)] << Make Combined Data Table;
by following this example: 46983 - How to make a combined data table of Summary Statistics from a Distribution report when usin....
However, I am still unable translate it into my work flow, maybe because the table I want has no title (e.g. "Parameter Estimates"). Below is an example of one report. The circled portion is what I want to make into a data table. I've included a sample of the script I'm using at the bottom. The challenge is how to add the circled data from ~100 reports generated at once into one data table. I've added a screenshot of the final table I'm looking for, that I'm currently entering manually into Excel (yuck). I would also need a way to add the model # (e.g. 633) to each row.
Thanks again for your help!
JP
7401_Screen Shot 2014-10-08 at 9.50.09 AM.png7402_Screen Shot 2014-10-08 at 9.52.32 AM.png
Here's an example of the script I'm using:
Fit Model(
  Censor( :Dispersed),
  Censor Code( "0" ),
  Y( :days to Dispersal ),
  Effects(  :Weight,:Year,:Source,:Translocation,:Treatment,:Geology,:Site,),
  Distribution( Frechet ),
  Dispatch(
  Parametric Survival Fit,
  OutlineBox,
  {Set Title( "Parametric Survival Fit - Model 632 " )}
Fit Model(
  Censor Code( "0" ),
  Effects(  :Weight,:Year,:Source,:Translocation,:Treatment,:Geology,),
  Dispatch(
  OutlineBox,
  {Set Title( "Parametric Survival Fit - Model 633 " )}
ian_jmp
Level X
Building on what Mark has explained, here's one way:
dt = Open("$SAMPLE_DATA/Reliability/Tobit2.jmp");
// Add a random 'by' column
byCol = dt << NewColumn("By", Numeric, Nominal, Formula(RandomInteger(1, 2)));
// Make the invisible report
fm = dt << Fit Model(
  Y( :YLow, :YHigh ),
  By(:By),
  Invisible
// Get a reference to the report layer
fmrep = fm << Report;
// This will be a list, one item per 'by' group
outlineTitle = fmRep << GetTitle;
// Make an empty display box
lub = LineUpBox(NCol(1));
// Add the content we need
For(o=1, o<=NItems(outlineTitle), o++,
  lub << Append(
  OutlineBox(outlineTitle[o],
  (fmRep[o])[TableBox(1)];
Close(dt, NoSave);
// Make a Journal
NewWindow("Report", << Journal, lub);
The only difficulty is to know which table boxes to include. To figure this out, right click on the triangle of the outline node, then select Edit > Show Tree Structure.
ian_jmp
Level X
Ooops! I see you wanted a table, not a journal. In which case 'Make Combined Data Table' is probably more direct.
Where I used "Parameter Estimates" in the subscript to target a particular outline box, you would instead use "Parametric Survival Fit - Model 633 ".
jpmontagne
Mark & Ian, thank you for your time! I'm still not getting this right though, because my version of the script below still won't produce a table. I've tried combining your two examples:
     Y( :height ),
     X( :weight ),
     Fit Line,
     By( :sex )
fmrep[1]["Parameter Estimates"][TableBox(1)] << Make Combined Data Table;
Any ideas?
Thank you,
JP
Jeff_Perkinson
You've got some subscripting errors in this line:
Instead it should be:
fmrep[Outlinebox("Parametric ?")][TableBox(1)]<<make combined data table;
You could use Outlinebox(1) or put the full title in there but the wildcard "?" makes it a little more general.
-Jeff
-Jeff
jpmontagne
Alright, so we're getting closer. Even though I pasted the wrong script, Jeff gave me the right answer. The following script provides the desired table for the sample data:
  Y( :YLow, :YHigh ),
  By(:By),
fmrep[1][Outlinebox("Parametric ?")][TableBox(1)]<<make combined data table;
Close(dt, NoSave);
// This script works the way it's supposed to!!
But why is it that when I remove byCol = dt << NewColumn(...)  and By(:By),the script no longer produces a table?
And since my goal is to create a single combined data table from multiple reports, how do I get the following sample script to work:
  Y( :YLow, :YHigh ),
  Effects( :age, ),
  Y( :YLow, :YHigh ),
  Y( :YLow, :YHigh ),
fmrep1 = fm1 << Report;
fmrep1 [1][Outlinebox("Parametric ?")][TableBox(1)]<<make combined data table;
THANKS EVERYBODY!!!
JP
Jeff_Perkinson
  Y( :YLow, :YHigh ),
  Effects( :age, ),
  Y( :YLow, :YHigh ),
  Y( :YLow, :YHigh ),
combined <<Split(
  Split( :Column 2 ),
-Jeff
-Jeff
