Lino
Script to do cumulative sum until meet certain limit
My data table starting with 3 columns, Date, Test_Qty and Fail_Qty.
I am creating script for 2 new columns, Cumulative_Sum_Test_Qty and Cumulative_Fail_Qty.
In Cumulative_Sum_Test_Qty column, the test qty is cumulative sum from current rows to previous row to meet 300 qty to form one lot of data.
In Cumulative_Sum_Fail_Qty, the fail qty is cumulative sum from current row to previous rows corresponding to cumulative sum test qty take place.
I am get stuck when creating the script for the cumulative sum for the both columns.
Can anyone provide help here
Re: Script to do cumulative sum until meet certain limit
OK.....I appreciate the clearer definition.  The script below seems to work on your test data
dt << New Column( "Cumulative_Sum_Test_Qty" );
dt << New Column( "Cumulative_Sum_Fail_Qty" );
dt:Cumulative_Sum_Test_Qty[1] = dt:Test_Qty[1];
dt:Cumulative_Sum_Fail_Qty[1] = dt:Fail_Qty[1];
holdTest = dt:Test_Qty[1];
holdFail = dt:Fail_Qty[1];
For( theRow = 2, theRow <= N Rows( dt ), theRow++,
	If( dt:Cumulative_Sum_Test_Qty[theRow - 1] > 300,
		holdTest = :Test_Qty[theRow];
		holdFail = :Fail_Qty[theRow];
		curRow = theRow;
		While( holdTest < 300,
			curRow = curRow - 1;
			holdTest = holdTest + :Test_Qty[curRow];
			holdFail = holdFail + :Fail_Qty[curRow];
		dt:Cumulative_Sum_Test_Qty[theRow] = holdTest;
		dt:Cumulative_Sum_Fail_Qty[theRow] = holdFail;
		dt:Cumulative_Sum_Test_Qty[theRow] = dt:Cumulative_Sum_Test_Qty[theRow - 1] + dt:Test_Qty[theRow];
		dt:Cumulative_Sum_Fail_Qty[theRow] = dt:Cumulative_Sum_Fail_Qty[theRow - 1] + dt:Fail_Qty[theRow];
Here is a solution.  I am assuming as soon as you go over 300 you restart.  If you need to stop before you go over 300, the logic change is pretty simple.
		dt:Cumulative_Sum_Test_Qty[theRow] = dt:Test_Qty[theRow];
		dt:Cumulative_Sum_Fail_Qty[theRow] = dt:Fail_Qty[theRow];
Lino
Thanks Jim.
What I needed is after go over 300, in the following row, new cumulative sum take place again until go over 300,...
It is kind of backward moving cumulative sum.....  This where I get stuck.
		curRow = theRow;
Lino
Thanks Jim. It works.
I study the script logic you provided. This help me enhance my knowledge.
I appreciate your help and guidance.
Thank you.
