I would like to clarity on my question that I meant "is there a script that I can run it to change the data type from numeric to character instead of manually change the columns one by one?"
You could write a script to do that but it's not necessary. Select the columns you want to change and choose Cols->Standardize Attributes. That will let you change data type, modeling type, column properties, etc. for many columns at once.
-Jeff
videodata.push(data[i]);
catch(e){
/* Re compile html */
/* Adding Translation flag */
if (tr_obj.length > 0) {
try {
} catch (e) {
} else {
try {
tr_para.appendChild(tr_fTag);
else {
} else {
} catch (e) {
} else {
// syncList.remove(value);
if (index > -1) {
}else {
if (value == '412846' && "ForumTopicPage" == "TkbArticlePage") {
/* V1.1 Remove from UI */
var sub_L = "";
if(value == '412846') {
}else{
sub_L = newSub.innerHTML;
else{
} else {
try{
catch(e){
if (value == '412846') {
if(subTkbElement){
try {
if(subElement) {
subElement.innerText = sub_L;
} catch (e) {
else {
try {
} catch (e) {
else {
try{
} else {
} else {
catch(e){
} else {
try {
else{
} catch (e) {
// Label translation
if (!labelEle) {
if (labelEle) {
if (listContains) {
trLabels = [];
trLabelsHtml = "";
/* try{
for(var j=0;j,';
trLabelsHtml = trLabelsHtml+'
