chadyoder
Script to clear a data filter back to original data table
Hello,  I have a large data set that I want to generate multiple types of graphs for.  There is a column with 18 different categories that I want to create a set of graphs for.  So I have this data filter script:
Current Data Table() << Data Filter(
Location ( { 30, 30}),
Mode (Select ( 0), Show (1 ), Include (1)),
Add Filter(
columns (:X),
Where(:x == "A"),
Display (:X, Size (204, 174), List Display)));
That data filter works and I can run my graph builder.  But, then I want to then clear my data filter and change the name from A to B and rerun the graphs for that.  I also want to be able to put all of this into one long script so I can click run and generate all this at one time.  It's a weekly process.  Anyway does anyone know how to do that.  I know there is a clear function for this but I can not figure out how to script that to get it to work.
Any help would be great.
Thanks,
Chad
chungwei
Staff (Retired)
Re: Script to clear a data filter back to original data table
I used the data table Big Class, and did something like this:
Distribution(
  Automatic Recalc( 1 ),
  Continuous Distribution( Column( :weight ) )
value = { 12, 13, 14, 15};
obj = Current Data Table() << Data Filter(
  Location( {30, 30} ),
  Mode( Select( 0 ), Show( 1 ), Include( 1 ) ),
  Add Filter( columns( :age ), Where( :age == value[1] ) )
for (i=2, i<5, i++,
obj << clear
obj << (filter column (:age) << where (:age==value[i]));
wait(1)
chungwei
Staff (Retired)
is this what you have in mind ?
value = { 12, 14};
obj << clear
obj << (filter column (:age) << where (:age==value[2]));
ian_jmp
Depending on exactly what is required, an alternative approach may be to manipulate the row states directly:
NamesDefaultToHere(1);
// List of 'by' variables
byCols = {:age, :sex};
// Loop over 'by' variables
for(c=1, c<=NItems(byCols), c++,
  // What are the levels of this variable
  levs = AssociativeArray(byCols[c]) << getKeys;
  // Loop over levels
  for(i=1, i<=NItems(levs), i++,
  // Start with a clean slate
  dt << clearRowStates;
  // Template expression to select rows appropriately
  CMD = Expr(dt << selectWhere(byCol != lev));
  // 'Bake in' the current values
  SubstituteInto(CMD, Expr(byCol), byCols[c], Expr(lev), Eval(levs[i]));
  // Finally make the selection
  CMD;
  // Hide and exclude
  dt << Hide << Exclude;
  // Make graphs . . .
  Wait(1);
If it's Graph Builder specific, you could also take advantage of the fact that it will actually consume a 'by' variable when you launch it.
chadyoder
That is what I would like to do.  I put the clear statement after my graph builder script and before the new data filter script.  Is that the correct place for it?  If so it did not clear data filter and allow me to change the setting of the filter.  It just stayed the same.
chungwei
Staff (Retired)
Distribution(
for (i=2, i<5, i++,
obj << clear
wait(1)
