ShahirahLoqman
Script to Delete Columns Not Containing a Certain Word
Hi, how do I write a script to delete columns not containing a certain word? I would like to delete column names that do not have the word "4C4QC30.0" in them
My script below unfortunately does not work:
For( i = 11, i <= N Cols( dt1_new ), i++, // set number of columns to start looking at
If( (Column( dt1_new, i ) << Get Name) != "4C4QC30.0.Cv", //
dt1_new << Delete Column ;
thanks!
Re: Script to Delete Columns Not Containing a Certain Word
Here are the minor changes to your code to make it work.  Note the looping going from the last column to your 11th column.  That allows for using the column number for deleting.
dt1_new = Current Data Table();
For( i = N Cols( dt1_new ), i >= 11, i--, // set number of columns to start looking at
	If( Contains( Column( dt1_new, i ) << Get Name, "4C4QC30.0.Cv" ) == 0,
		dt1_new << Delete Columns( i )
