matt_p
Script for saving to PDF
Hi all,
I have a bunch of graphs that I would like to save to a pdf.
I currently have
Current Journal()<<Save PDF("C:\Documents and Settings\My Documents\myFile.pdf")
This will save my journal as a PDF, but it will be horribly out of scale and across multiple pages.
If I go through File -> Save As -> PDF then I can chose options for scaling/landscape etc.
Is there anyway to get these options for a script? I can't seem to find anything in the guide or index.
Thanks for your help!
-Matt
carole
Re: Script for saving to PDF
Hi all,
here is JSL (JMP10) I use to do what is wanted I think...
Regards.
winJOURNAL = CurrentJournal();
//Define setup information to save in pdf
winJOURNAL         <<     Set page setup(
    margins( 0.5, 0.5, 0.5, 0.5 ),
    scale( 0.8 ),
    portrait( 0 ),
    paper size( "A3" )
winJOURNAL         <<     get page setup();//get setup information
//Save as PDF
winJOURNAL        <<    SavePDF("C:\Documents and Settings\My Documents\myFile.pdf");
8 REPLIES 8
joeyjamboadl
Hi Matt,
I have a similar problem. Did you get any resolution?
Regards
JJ
tova
I would also like a resolution if anyone's found one...
carole
Hi all,
Regards.
    scale( 0.8 ),
    portrait( 0 ),
    paper size( "A3" )
//Save as PDF
KinKame
exactly what I needed as well ... JMP is so nice :)  ... my Christmas present
kahart
I have had a similar issue.  I found that if I set the window size for each graph prior to adding it to the Journal, I was able to print the Journal and the graphs.
example:
graph1 << size window(920,800);
winJournal()["Graph"] << Apend(Outline Box("Graph",graph1);
I also used similar code as that above for page setup and also had to set the window size for the Journal;
    scale( 0.7 ),
winJOURNAL         <<    Set Window Size(920, 1000);
It took some time to get the sizes correct based on the graphs.  I found it is very important to go through this effort and to test it with different display resolutions.   Generating a pdf with a lower display resolution will change the scale of the graphs.
arronlee
Yup indeed, I agree with kahart. Generating a pdf with a lower display resolution will change the scale of the graphs. So have you found out any fine PDF tools to deal with the problem?
none1
I always do save as ---> PDF and so on.
You can make adjustments to the size of the page, however I have to agree, this is a very bad interface to generate business suitable pdfs.
I hope JMP will look at this issue seriously.
Regards
mattyclown
I do not think a 3rd pdf creating tool can offer any proactical help. Maybe you can have a look at following post which uses code to handle the scaling issue of image in pdf.  Anyway, we are looking forward to the expert to offer some guidance.
r - saving graph in pdf or png scaling issue - Stack Overflow
