mkennke
Script for Control Charts (all numeric Columns) with saved Limits in one table
I'm trying to generate one Window/Report with several Control Charts (all numeric columns of the data table). So far I was able to generate this report. But I'm not able to save all Limits in one data table. Can anybody help me?
Following my code
dt = Current Data Table ();
//Deselection von allen Spalten
cols = dt << get column names();
For(i = 1, i <= N Col(dt), i++,
    cols[i] << set selected (0)
//Selection
cc = dt << Get Column Names( numeric );
ncols = N Items( cc );
For( i = 1, i <= ncols, i++,
cc[i] << Set Selected( 1 )
nw1 = New Window ("Control Charts");
test = cc[i];
conc = Control Chart(
	Group Size( 1 ),
	KSigma( 3 ),
	Chart Col(as Column (test) ),
	Chart Type( Moving Range )
); nw1 << append (Report(conc)); conc << Close Window);
nw1 << in New Table;
Re: Script for Control Charts (all numeric Columns) with saved Limits in one table
Here is my solution to your code.  I commented out code that I did not see was serving any purpose for this specific issue
/*cols = dt << get column names();
For( i = 1, i <= N Col( dt ), i++,
	cols[i] << set selected( 0 )
//Selection
/*ncols = N Items( cc );
nw1 = New Window( "Control Charts" );
For( i = 1, i <= N Items( cc ), i++,
	Current Data Table( dt );  // Should not be required, but script would not work without it
	conc = dt << Control Chart( Group Size( 1 ), KSigma( 3 ), Chart Col( As Column( cc[i] ) ), Chart Type( Moving Range ) );
	concDT = conc << in New Table;
	concDT << New Column( "Column", character, set each value( Char( cc[i] ) ) );
	Column( concDT, Char( cc[i] ) ) << set name( "Value" );
	If( i == 1,
		baseDT = concDT,
		baseDT << concatenate( concDT, append to first table( 1 ) );
		Close( concDT, nosave );
	nw1 << append( Report( conc ) );
	conc << Close Window;
//Selection
	If( i == 1,
		baseDT = concDT,
mkennke
Thank you very much. It works perfectly. It will save so much time  :)
ian_jmp
Level X
. . . and here's an alternative using column properties:
NamesDefaultToHere(1);
// Make a table with some random data
dt = NewTable("Charts");
n = 5;
dt << addMultipleColumns("C_", n, Numeric);
dt << addRows(20);
for(c=1, c<=n, c++, Column(dt, "C_"||Char(c)) << formula(RandomNormal(0, 1)));
dt << runFormulas;
// Put the charts into a single window
nw1 = New Window ("Control Charts",
			For( c = 1, c <= n, c++,
					thisCC = dt << Control Chart(
												Group Size( 1 ),
												KSigma( 3 ),
												Chart Col(Column(dt, "C_"||Char(c))),
					// Save the computed limits as a column property
					thisCC << inColumn;
// Make a blank limits table
dt2 = NewTable("Limts",
				NewColumn("Column", Character),
				NewColumn("Avg", Numeric),
				NewColumn("LCL", Numeric),
				NewColumn("UCL", Numeric),
				<< addRows(n)
// Populate the limits table by parsing the saved column property
	clExpr = Column(dt, "C_"||Char(c)) << getProperty("Control Limits");
	Column(dt2, "Column")[c] = "C_"||Char(c);
	Column(dt2, "Avg")[c] = Arg(Arg(Arg(clExpr, 1), 1), 1);
	Column(dt2, "LCL")[c] = Arg(Arg(Arg(clExpr, 1), 2), 1);
	Column(dt2, "UCL")[c] = Arg(Arg(Arg(clExpr, 1), 3), 1);
I suspect this might be simpler with Control Chart Builder, but I didn't check (and you may have reasons for using the 'old' platform anyway).
