tikhahabusamah
Script auto run all selected subset
is there any possibility to run all subset column by name which consist of more than 50 name automatically at the same time?
when I did subset by name, i get all those detail data I want, but I need to click one by one to run fit y by x analysis. is there is a way for me to select all and automatically run fit y by x analysis? all of this subset name might changes everytime.
ts2
ts2
Re: Script auto run all selected subset
FYI when subsetting you can assign your subset tables as a list rather than using N Table() which could be problematic if you have a bunch of other tables open (typically including the original table subset from).
// Perform the subsets
listDT = dt << Subset(
	By( :age ),
	All rows,
	Selected columns only( 0 ),
	columns( :name, :sex, :height, :weight )
// Loop across all new data tables and run Fit Y by X
For( i = 1, i <= N Items( listDT ), i++,
	listDT[i] << Bivariate( Y( :height ), X( :weight ) )
Here is a little script that shows and example of one way to do what you want
// Get the current number of data tables
numDT = N Table();
dt << Subset(
	By( :age ),
	All rows,
For( i = 1, i <= N Table() - numDT, i++,
	Data Table( i ) << Bivariate( Y( :height ), X( :weight ) )
tikhahabusamah
I try to did split by name after subset, which is before run table fit Y by X, but everytime I try to run JMP become not responding anymore. why?
numDT = N Table();
dt << Subset( By( :age ), All rows, Selected columns only( 0 ), columns( :name, :sex, :height, :weight ) );
    Data Table( i ) << Split( Split By( :name ), Split( :sex, :height, :weight ) )
The issue is the stopping value for your For() loop.  You are specifying
and then in your code you are creating a new data table, so the next time the loop happens, the value of
N Table()
has increased by an additional count, so the variable 'i' can never get to the current value of N Table()
ts2
ts2
	By( :age ),
	All rows,
@tikhahabusamah
Remove my solution ( @txnelson ) and select @ts2  as the solution.  It is a better solution!
