kuanaunwei
[Script] Color Gradient Output
R1=(dt<< Tabulate(
Show Tooltip( 1 ),
Add Table(
Column Table( Statistics( N )),
Column Table( Grouping Columns( :Name( "TEST" ) ), Statistics( Row %, N )),
Row Table( Grouping Columns( :Radius ) )
)) << Make Into Data Table;
R1:"N(1)"<< Set Property( "Color Gradient", {"White to Orange", Range( {0, 547, 187.945945945946} )} )
<< Color Cell by Value;
R1:"N(8)"<< Set Property( "Color Gradient", {"White to Orange", Range( {0, 547, 187.945945945946} )} )
R1:"N(9)"<< Set Property( "Color Gradient", {"White to Orange", Range( {0, 547, 187.945945945946} )} )
The output of the script above is combined together. Therefore the colour gradient that is set for N(1), N(8), N(9) has combined, how do i seperate each N(s) to have their own specific colour gradient
10 REPLIES 10
kuanaunwei
Re: [Script] Color Gradient Output
Hi, yes this was the issue i was trying to solve. Thanks alot for the help and guidance. Sorry for my poor english. Thanks
