Scatterplot 3D tiff resolution
Dear community,
I wish to export a 3D scatter plot at a high resolution. Once I do this (600 or 1200 dpi) the data frame is clean, but the actual plotted data and axis are still pixelated. See attached image.
Is there a method for exporting 3D plots in high resolution?
Thank you,
-Lucas
ih
Super User (Alumni) ih
Re: Scatterplot 3D tiff resolution
Try resizing the graph (make it larger) before saving the image rather than changing the dpi of the saved image.  With a script you can make the image much larger than your monitor size.
Names default to here(1);
dt = Open("$SAMPLE_DATA/iris.jmp");
s3d = dt << Scatterplot 3D(
	Y( :Sepal length, :Sepal width, :Petal length, :Petal width ),
	Frame3D( Set Graph Size( 2000, 2000 ) )
s3d << Save Picture("$DESKTOP/image.png","png");
ih
Thank you. I will try this asap.
