Josee
Saving Summary Table as HTML and Picture
I am trying to save the summary table as an HTML and a picture but both scripts do not work. How can I get it to work?
jrnl<<save HTML and jrnl<<save picture do not save as I need it to. Any help will be much appreciated.
Example:
dt1=dt<< Summary(
Group(:sex),
Mean( :height )
dt1<< sort( by( :Name("Mean(height)")),Order(Descending), Replace Table );
jrnl=dt1<<journal;
jrnl<<Save HTML ("path/Summary.html");
Re: Saving Summary Table as HTML and Picture
With JMP 12, the simple assigning of a variable to the journal does not work, you will have to use a
     xxx = Current Journal;
to get the correct pointer to the journal.
See below
dt1=dt<< Summary(
Group(:sex),
Mean( :height )
jrnl=dt1<<journal;
zippy=current journal();
zippy<<Save HTML ("C:\Users\joseebon\desktop\Summary.html");
8 REPLIES 8
I suspect that
     "path/Summary.html"
does not point to an actual location.  That is, do you have a folder named "path" as a folder at the top of your OS system.
I suspect that is if you change "path" to an actual writable folder on your hard drive you will not have an issue.
I made that change and the Save HTML worked just find.
Josee
yes I do direct it to a writable path. for example this is what I am trying to do and it is stilll not wanting to save on my desktop.
dt1=dt<< Summary(
Group(:sex),
Mean( :height )
jrnl=dt1<<journal;
jrnl<<Save HTML ("C:\Users\joseebon\Desktop\Summary.html");
What is the error message in your Log?
Josee
There are no errors on the log. This is what is showing up.
dt1=dt<< Summary(
Group(:sex),
Mean( :height )
jrnl=dt1<<journal;
Scriptable[]
Are you running JMP 14?
Josee
No I am running on JMP Pro 12.
See below
dt1=dt<< Summary(
Group(:sex),
Mean( :height )
jrnl=dt1<<journal;
Josee
It works perfect. Thank you.
