Saving Row States, cannot find the "Add From Row States "
Created:
Aug 9, 2021 05:30 PM
| Last Modified: Jun 10, 2023 4:35 PM(3274 views)
I am trying the save my row states so later I can return them. I added a new column and changed the data type to Row State. Then when I try to add/copy the row states to the new column, I cannot see the buttons described in videos or forums. I am missing something? It should be easy to set this up, but I could not find the Add or Copy options when I right click on the new column.
