uProf
Saving Multiple Data Tables to an Excel Workbook
Hi -
I have a jsl script made with Jmp 12 that processes huge data table and generates 9 data tables with different summaries.
I am saving these off currently as 9 csv files. I would like to condense it to ONE Excel workbook with 9 tabs.
I understand saving each data table to excel (xlsx) is an option. How can I have 9 sheets saved to one excel via Jmp 12?
Appreciate any inputs/pointers. Thanks!
Thierry_S
Re: Saving Multiple Data Tables to an Excel Workbook
I am not sure if this command is available in JMP 12, but in more recent version, you can use the following:
dt1 = Open( "$SAMPLE_DATA/Big Class.jmp" );
dt2 = Open( "$SAMPLE_DATA/Abrasion.jmp" );
Create Excel Workbook(
	"$TEMP/MyWorkbook.xlsx",
	{dt1, dt2},
	{"Big", "Abrasive"}
With the first List being the data tables you need to aggregate and the second list being the names of the worksheets.
Let us know if this helps?
Best,
TS
Thierry R. Sornasse
uProf
Thanks Thierry. This does not work on Jmp 12. I do look forward to using this feature once I upgrade to newer Jmp version.
