I have been saving graphs as PNG images at higher than default DPI so that they can be resized cleanly in other programs like powerpoint. Recently I made the switch from JMP 16 to JMP 17 and the setting no longer seems to work -- is there some other setting now that governs saved image resolution? Here's an example: I saved the same plot with two different DPI settings and the resulting PNGs are identical.
Thanks for posting this item! It has been seen by JMP Development, and i can confirm that there will be a fix for this in the next release of JMP, the next update to JMP 17.1, which will be available within a couple of months.
videodata.push(data[i]);
catch(e){
/* Re compile html */
/* Adding Translation flag */
if (tr_obj.length > 0) {
try {
} catch (e) {
} else {
try {
tr_para.appendChild(tr_fTag);
else {
} else {
} catch (e) {
} else {
// syncList.remove(value);
if (index > -1) {
}else {
if (value == '580696' && "ForumTopicPage" == "TkbArticlePage") {
/* V1.1 Remove from UI */
var sub_L = "";
if(value == '580696') {
}else{
sub_L = newSub.innerHTML;
else{
} else {
try{
catch(e){
if (value == '580696') {
if(subTkbElement){
try {
if(subElement) {
subElement.innerText = sub_L;
} catch (e) {
else {
try {
} catch (e) {
else {
try{
} else {
} else {
catch(e){
} else {
try {
else{
} catch (e) {
// Label translation
if (!labelEle) {
if (labelEle) {
if (listContains) {
trLabels = [];
trLabelsHtml = "";
/* try{
for(var j=0;j,';
trLabelsHtml = trLabelsHtml+'
