amurphy
Saved Log vs. Viewed Log Contain Different Content
I have a table that I've manually edited extensively and am looking to save the script for so I can automate in the future. I've written the following script (intended to be pasted into data table or allow user to run independently), which works, but I have to copy & paste into a text file to save:
dt = Current Data Table();
If( Is Empty ( dt ),
	Try( dt = Open(), Throw("No data table found"))
Open Log();
dt << Get Script;
If I add the line Save Log (" "); it correctly saved the log, but only up to the transcript of the executed script and no longer contains the output of dt << Get Script;. I've tried many iterations of reordering the commands, but can't get the saved log to match the viewed log:
Open Log();
dt << Get Script;
Save Log("");
Craige_Hales
Re: Saved Log vs. Viewed Log Contain Different Content
dt << Get Script;
gets the script, but doesn't do anything with it. Try
write(dt << Get Script);
JMP's behavior when evaluating an expression (even an expression with a bunch of semicolon separated statements) is to print the last result. So, when your submitted script ends with dt<<GetScript, that's what winds up in the log. Otherwise, the <<GetScript method is evaluated, the value is returned, then as soon as another statement executes, the value is thrown away in favor of the next statement's result.
You may need a newline in the write, something like write("\!n", dt<<GetScript). The write function adds nothing to the value that is printed, unlike the print() and show() functions.
Craige
Craige_Hales
dt << Get Script;
Craige
amurphy
Thank you! That solved my immediate problem and taught me some new basics that will help a lot in the future!
