Celine1
Save summary in control chart
I'm using JMP 17. i would like to save a summary in excel file that include product name.
is it able to phase twice to get another column which is product name?
else
Can advise me how to add another column named product name in the summary?
dt = PT << Save Summaries;
Current Summary
Output that I hope to get is have 3 columns which is Line, Profile Start Time and Product Name
SDF1
Re: Save summary in control chart
Hi @Celine1 ,
  Do you know when a product type is being made? For example, are only certain products made during the phases that you show in your control chart? If so, you could make a column formula that is based on IF statements about whether it's Line 1 or Line 2, or Phase 1 or Phase 2 and assign the row value to a certain Product A, B, or C, and so on.
  Or, if you have an anonymized data table to share, then it might be easier for someone to generate the analysis you're interested in and save it to the data table and post it back to the thread. Just a thought.
Hope this helps,
DS
