kd_kel
Save script to data table (All objects )
How do I use the save script to data table (all object)  syntax to save a data table sorted : by a column
Re: Save script to data table (All objects )
Is this what you are looking for
obj = dt << bivariate(x(:weight),y(:Height),
	By( age )
obj[1] << Save ByGroup Script to data table;
If you used
     Tables->Sort
then the script has already been saved to the data table in the form of the Source entry in the Tables Panel.
kd_kel
Thanks Nelson,
how about a report grouped by: a column. The report has multiple sections grouped by a column and I need to save them all to the data table
	By( age )
kd_kel
worked perfectly !
Thanks Nelson !
