yanee
Save residual by using jmp script
I created a script to run a correlation.  there are 2 fit line : a) linear correlation fit , b) 1:1 fit.
I need to save the residual from the 1:1 fit (fit special). how do I do that with the JMP script ?
plot = data table("Correlation_Raw")<< Bivariate(
Y( :NewTester ),
X( :RefTester ),
Fit Line( {Confid Curves Fit( 1 ), Line Color( {212, 73, 88} )} ),
Fit Special( Intercept( 0 ), Slope( 1 ), {Line Color( {61, 174, 70} )}),
By( :Label )
bivRep = plot << Report;
Thanks.
Yanee
Re: Save residual by using jmp script
Here is a simple modification of your script that will save residuals for both of your fits.
Y( :NewTester ),
X( :RefTester ),
By( :Label )
plot << (Curve[1] << Save Residuals);
plot << (Curve[2] << Save Residuals);
See the Scripting Index for other examples
     Help==>Scripting Index==>Bivariate==>Save Residuals
Y( :NewTester ),
X( :RefTester ),
By( :Label )
yanee
thanks ...
