gutloja
Save "Predicteds" with a specific column name
Hello, All.
Quick question.
Is there a way to save predicteds with a specific column name?
When I use something like this to save predicteds:
Bivariate << (curve[1] << save predicteds);
It saves as "Predicted Name of predicted variable".
Thank you for your time & help,
-JoseL
Re: Save "Predicteds" with a specific column name
Because JMP will save the predicted as a new column at the far right of your data table, you can use the following code to change the name to whatever name you want to give it:
Assuming you have referenced your data table using a variable called "dt" (i.e. dt=current data table();)
column(N Cols(dt)) << set name("Your new name");
gutloja
Thanks a lot Jim, this worked like a charm.
-JL
mredford
Hi, I'm trying to do this as well. Did you save the predicteds column manually, or was this scripted? I'm hoping to automate the process and script the saving of the column, so if you scripted this, could you share the syntax you used? Thanks!
Here is a sample script that you should be able to use
dt = Open( "$SAMPLE_DATA\semiconductor capability.jmp" );
biv = Bivariate( Y( :NPN1 ), X( :PNP1 ), Fit Line( {Line Color( {213, 72, 87} )}, save predicteds ) );
biv << (curve[1] << save predicteds);
Column( N Cols( dt ) ) << set name( "Your new name" );
mredford
Perfect! Thank you so much, I have been struggling all morning to automate this for the spline fit. Thank you for your quick response as well!!
