yossi_tokash
Save data table with tab delimiter through script
Hi Guy's,
Is is possible to save a jmp data table to a text file with tab delimiter using a script ?
Thanks in advance,
Yossi
gzmorgan0
Re: Save data table with tab delimiter through script
Yes. Here is an example.
Names Default to Here(1);
dt = Open("$Sample_Data/Big Class.jmp");
//modified excerpt from JSL Companion script "2_Extra_SaveText.jsl"
// Save as text with tab delimiters
// Get user Export Preferences
xptPref = Get Preferences( Export Settings );
// Set desired Export Preferences
Preferences(
	ExportSettings(
		End Of Line( CRLF ),
		End Of Field( Tab ),  //optionally try: Comma|Space|Other("|")|Other("^") etc
		Export Table Headers( 1 )
// Save as .txt
dt << Save( "c:/temp/bigclass_tabs.txt" );
// Reset user Export Preferences
Eval( xptPref );
// xptPref;  // works as well.
gzmorgan0
Preferences(
	ExportSettings(
// Save as .txt
Eval( xptPref );
