Dennisbur
Save data as Excel file and immediately open it on the computer
Hello
I would like to save data in an Excel file and open it
I have written the command at the end of the script
I see JMP saved the data as well, but don't open the file in Excel
what I have missed in JSL?
dt_excel = dt_p << Save( "C:\Users\dburmist\Downloads\Bucket.xlsx" );
dt_excel = dt_p << open( "C:\Users\dburmist\Downloads\Bucket.xlsx" );
mmarchandTSI
Level V
Re: Save data as Excel file and immediately open it on the computer
The Open() function is not a message to send to a data table.  <<Open() as a message is used to show or hide values in a Matrix Box or specify an image to add to a PictSeg.  When you tell JMP to Open() an Excel file, it imports it into JMP; it doesn't open it in Excel.  If that's what you want, you'll probably need to Run Program().
You can use Web() to open the excel file
savepath = Convert File Path("$TEMP/Big Class.xlsx", windows);
dt << Save(savepath);
Web(savepath);
Other option would be to use Run Program
