Hegedus
Save Residuals to Summary Table Problem
I have a table with 400k+ rows and in my analysis I have created a summary table.
I do a fit Y by X on the summary table and get what I expect.  From the pull down I select "Save Residuals" and the new column is not created on the summary data table, but on the original data table.  Is this the intended operation?  The work around is to separately save the summary data table to break the linkage.  Or is this a bug?
Andy
Re: Save Residuals to Summary Table Problem
The issue is that your summary data table is linked to your original data table.  What you need to do, is to unselect the Lint to Original Data Table checkbox when you create the summary data table:
Hegedus
Is this a change in behavior?  I have been using JMP since it came on 3 1/2" floppies and never remember having seen this.
Andy Hegedus
I guess we would have to query the JMP Historian to find out the answer to your question.  It has been a long time behavior.
chungwei
Staff (Retired)
What version of JMP are you using ?
I tried doing something similar in version 12.2, and the columns are saved to the summary table as I expected.
This is what I did :
dt = open("$Sample_Data/Big Class.jmp");
dtsumm = dt << Summary(
Group( :age ),
Mean( :height ),
Mean( :weight ),
obj = dtsumm << Bivariate(
Y( :Name( "Mean(height)" ) ),
X( :Name( "Mean(weight)" ) ),
Fit Line( {Line Color( {208, 64, 86} )} )
obj << (Curve[1] << Save Residuals);
The residuals were saved to the summary table as I expected.
