elu
elu
Sample size, power and TOST for a comparability/equivalence test against a gold standard
I have a historical dataset as a baseline (key product measure) for a manufacturing process, then the process has changed due to optimization. How do I: 1)  estimate sample size and power for a comparability study? 2) use TOST to establish if the product from the optimized process produced the same/comparable product? (assuming equal variance between the 2 datasets)
For the 1) my current approach is to use std dev from the baseline dataset, set alfa = 0.05 and 'difference in mean' using delta between 'baseline mean' and 'the failure value/lower spec' , from that I can chose a power to get the sample size from DOE>Design and Diagnostics>Sample Size and Power>Two Sample Means. Is this approach correct?
For the 2) I have never done it so I am seeking an expert answer please.
Thanks a lot,
Ed
6 REPLIES 6
Re: Sample size, power and TOST for a comparability/equivalence test against a gold standard
See Help > Books > Design of Experiments Guide > Prospective Sample Size and Power chapter. Your definition of the similarity interval is not unreasonable. However, if the mean has shifted to the specification, you might determine that the equivalence is significant while experiencing many individual units out of specification. The specification is about each unit. The mean is about the population. The equivalence test is about the population.
See Help > Books > Basic Analysis > Oneway Analysis chapter.
elu
elu
Thanks for the reply. I think I am still looking for a population comparison with TOST, given that I can get a dataset with valid sample size and study power.
That is correct. The TOST is for the population mean. So is the (Target - Spec) interval reasonable for the tolerance in the test?
elu
elu
Right. what is the right approach to obtain tolerance interval in my case and how to use it in TOST?. I have just one failure spec limit and a historical dataset that reflects key product potency and releases the product from the old process.
Thanks again for your reply.
Ed
I can't tell if you are confirming my previous reply or asking for clarification. If you were asking for more help with TOST in JMP, see the reference I gave earlier for Oneway. It is all there with examples. Please post any further questions that you might have.
elu
elu
Thanks
