tgp109
How to delete rows based upon a condition
I have a joined data table and i would like to select & delete rows if two condition are both simultaneously met.
Character Condition1= Missing a name in column ("NAME")
Character Condition2= Character value in column ("NO") is L9% & exists where there are various character values in the table (ie. L921000, L939456, L999999, etc.)
Is there a way to do this since i don't think i can use an sql wildcard% or do i need to change this column to a number (by removing the L & changing it from character to numeric) and then i can chose values >899,999.
The error is in the 2nd part of my select where statement dealing with condition 2 (L9 character values)
DATA3=Data Table( "DATA1" ) << Join(
With( Data Table( "DATA2" ) ),
Merge Same Name Columns,
By Matching Columns( :NO = :NO ),
Drop multiples( 1, 1 ),
Include Nonmatches( 1, 1 ),
Preserve main table order( 1 ),
Output Table( "MERGE3" )
DATA3 << select where((Is missing(:NAME)) & contains(as column(DATA3,"NO"),"L9")==2) << delete rows << clear select;
ms
Super User (Alumni) ms
Re: How to delete rows based upon a condition
Try the Left() or Starts With() function.
Example:
DATA3 << select where(Is Missing(:NAME) & Starts With(:NO, "L9")) << delete rows;
ms
Example:
