Simone1
Sample Size for DOE
I write you to have some suggestion regarding on topic linked to the DOE.
I have a industrial process. The outout (response) of the process is the percentage of scrap.
The average of this scrap is around 1.5%.
I want to create a DOE to identify main factors, interactions, model,...
My question is: how I can determine the number of the replicates for each corner (for a specific power) to be sure to have correct statisical results (if in one trial I will obtain "0% of scrap" it is real output change or only a case)?
Thanks in advance for your feedback.
Best Regards,
Simone
11 REPLIES 11
statman
Re: Sample Size for DOE
My suggestion is to be more creative in developing an appropriate response variable (and use multiple responses).  If color is the issue, there are multiple ways to measure this:
  • ∆L: the difference in lightness/darkness
  • ∆A: the difference in red/green values
  • ∆B: the difference in yellow/blue values
  • ∆C: the difference in chromaticity
  • ∆E: the spectral “distance” between the two colors
  • ∆H: the difference in hues
If human perception is of interest, then an ordinal scale might be very useful.  I have attached a paper I wrote to provide guidance on using such a scale.  Binary responses are not very descriptive, require larger sample sizes and lack discrimination.
Simone1
I understand your suggestion regarding the usage of some "∆" and tranform "OK/KO" in some data measurable.
Not easy... but not impossible.
Thanks also for the paper.
Have you a good day.
Best Regards,
Simone
