GiuseppeC
Dear All,
I would like to make a query on a database that contains two separate columns in which different genetic mutations are indicated.
Therefore I would like to look for two mutations at the same time.
I wrote the following program in SAS:
proc sql;
create table f.gat as
select *
from f.c
where mutation1 in ("G178R", "S549N", "S549R", "S549R (A-> C)", "S549R (T-> G)", "G551D", "G551S", "G1244E", "S1251N "," S1255P "," G1349D ")
or / and
mutation2 in ("G178R", "S549N", "S549R", "S549R (A-> C)", "S549R (T-> G)", "G551D", "G551S", "G1244E", "S1251N" , "S1255P", "G1349D");
run;
in JMP is it possible to write a program that does the same thing that SAS does? Is it possible to replace "in" with "not in" or different?
Thank you
Giuseppe
frank_wang
Re: SQL
Hi
JMP can query DB like below:
obj = New SQL Query( Connection( "ODBC:DSN=SampleDSN;" ), Custom SQL( "SELECT c1, c2, c3 FROM my_table;" ) );
Put SQL into 'Custom SQL()'. Details could be serched from script index with key word 'SQL'
心若止水
