ron_horne
SQL - cannot insert multiple comands into prepared statement
dear members of the forum,
when using jmp to query amazon redshift i need to send two statements together but for some reason this i get an error saying:
unfortunately, my query is very elaborate and doesn't work with just a "Where" statement for each separate table.
if anyone has any idea how to overcome this issue it would be helpful.
Thanks
pmroz
Re: SQL - cannot insert multiple comands into prepared statement
This approach might help:
Call a PL/SQL procedure that does the super-complex query, and creates a temporary table.
Then select * from the temporary table.
Here's some code that does something like that:
event_sql = evalinsert(
"DECLARE
	l_proc_name VARCHAR2 (100)	:= 'Get_Reference_PTs';
	l_user_SID 	NUMBER			:= SYS_CONTEXT('USERENV', 'SID');
	l_user_name	VARCHAR2 (30)	:= UPPER(SYS_CONTEXT('USERENV', 'OS_USER'));
BEGIN
    INSERT INTO quality_attrib (SID, OS_USER, Completion_Time, Progress_Text)
        VALUES (l_user_SID, l_user_name, SYSTIMESTAMP, 'START Get_Reference_PTs');
        COMMIT;
	INSERT INTO Ref_PT_List (SID, OS_USER, PT_Name)
	(SELECT DISTINCT l_user_SID, l_user_name, mu.pt_name
	FROM info ci,
		 drug cd,
	     reaction cr,
	     meddra_uta mu,
	 WHERE cd.case_id = ci.case_id
	   AND cr.case_id = ci.case_id
	   AND cr.reported_meddra_uta_id = mu.meddra_uta_id
	   AND cd.cdd_generic_id = rd.cdd_generic_id
	   AND ci.report_type_code_id = 8
	   AND rd.calendar_id =  ^one_calendar_id^
	   AND cd.drug_character_code_id IN (31, 32)
	^pt_clause^
	^date_clause^
	^event_type_clause^
	COMMIT;
        VALUES (l_user_SID, l_user_name, SYSTIMESTAMP, 'END Get_Reference_PTs');
        COMMIT;
EXCEPTION
    WHEN OTHERS
        THEN
        log_error_message(SQLCODE, SQLERRM, l_proc_name);
END; ");
Execute SQL(dbc, event_sql);
Execute SQL(dbc, "select * from ref_pt_list");
Georg
Dear Ron, I did Not Do This so far, but here you are asking new sql query for two tables, I suppose, it can not handle that. Did you try execute sql instead?
Other possibility would be union between both queries to have one only. But this requires exactly the same columns in same order.
Georg
ron_horne
i get the same error if i try it using the following script:
// connect to database - open data base
DBConnection = Create Database Connection(
"ODBC:DSN=database-project;EPWD=.....;");
sql_events =
select * from "public"."logs"  "t1";
dt1 = execute sql ( DBConnection,  eval insert ( sql_events , "¤") ,  "Events from logs"  );
the issue may be similar to this discussion:
https://community.jmp.com/t5/Discussions/SQL-query-to-ODBC-datasource-SQL-server-with-temporary-tabl...
but the solution there is not exactly applicable to redshift.
pmroz
Generally you can't execute two SQL statements with one call to EXECUTE SQL.  Both statements are the same; perhaps you were just showing an example?
Why are you trying to run two SQL statements at once?  EXECUTE SQL returns a dataset for each SQL statement.
Why not just run two EXECUTE SQL commands?
ron_horne
you are right @pmroz , it was just an example of two statements.
sometimes i need two statements to create a sub-sample (temporary table) or define a function.
in most cases i manage to use the "With" statement instead of a temporary table but not always. especially when using the "With" statements requires very complex sub-queries that are not allowed.   .
pmroz
"DECLARE
BEGIN
        COMMIT;
	FROM info ci,
		 drug cd,
	     reaction cr,
	     meddra_uta mu,
	^pt_clause^
	^date_clause^
	^event_type_clause^
	COMMIT;
        COMMIT;
EXCEPTION
    WHEN OTHERS
        THEN
END; ");
ron_horne
thank you very much @pmroz
splitting the two statements into separate Execute SQL statements works perfect.
