SQL Server login pop
I am using a JSL script to pull data from SQL server. That script worked fine with JMP 18 for months. Recently I updated JMP to version 19. Now when I run the same script I get SQL server login in pop up. How to fix this?
Re: SQL Server login pop
What version of the SQL Server driver are you using?
Also, have you tried the "test" button using the Windows ODBC Manager?
What you're seeing is a driver prompt, so any connection information you can provide would be helpful, not real values of course.
