Phil_Nash
SQL Query custom expression - date range
I am trying to pre-filter a Query based on date range, but can't figure out how to get it to work.  I keep getting this error.  I have to be missing something simple, right?
ErraticAttack
Re: SQL Query custom expression - date range
Try using
SYSDATE - 180
Jordan
ErraticAttack
Try using
SYSDATE - 180
Jordan
Phil_Nash
I wasn't thinking that I needed to write it in SQL... d'uh.
This worked;
t4.Date >= CAST(DATEADD(DAY, -180, GETDATE()) as DATE)
Georg
You Don't need to, but I really recommend this way, because it is easy and most effective. Btw I think you don't have to typecast the date, if database column is Set up correctly You can compare as date/number directly. Of course you can Do in JSL as well, but more complicated.
Georg
