ErraticAttack
SQL In() Function
Is anyone aware of what the SQL In() function is?  I don't see any documentation anywhere.  I'm using JMP Pro 16.2
Jordan
Re: SQL In() Function
The SQL IN Operator allows you to specify multiple values in a WHERE clause
SELECT column_name(s)
FROM table_name
WHERE column_name IN (value1, value2, ...);
