So I've got a large dt that I'm splitting from TALL to WIDE. This results in a huge qty of columns, all with the header format = "Step#_Parameter_Function".
The amount of these columns vary and are never predictable and set, nor are the step #'s or names.
How would i be able to then group these columns by Step#? Some sort of loop to scan through the long list of columns, pick out the first Step# and then assign it to a group labeled that "Step#"?
<< Split(
Split By( :recipe_step_id, :parameter_name, :aggregate_function ),
Split( :value ),
Group( :recipe, :equipment_id, :chamber_id, :wafer_scribe, :wafer_process_start_time ),
Output Table( "Wide" ),
Remaining Columns( Drop All ),
Sort by Column Property
