ben_ph
Running a TextEditBox's Set Text Changed script programmatically
Is it possible to run a TextEditBox's Set Text Changed script programmatically? I can use << setText("text", runscript(1)) if the TextEditBox's script is set with <<setFunction but not when it is set with <<setTextChanged.
New Window("Example",
    teb = Text Edit Box("Example Text",
        <<Set Text Changed(Function({this, value}, (this << sib) << settext(value)))
    Text Box("")
teb << setText("test", runscript(1)) // Works for <<setFunction
Thanks for any help!
ben_ph
Re: Running a TextEditBox's Set Text Changed script programmatically
This seems to work
    Text Box("")
teb << setText("abc");
f = teb << getTextChanged();
f(teb, "abc")
ben_ph
This seems to work
    Text Box("")
f(teb, "abc")
