Thierry_S
JMP > JSL > Col List Box [grouped] + [<< set data type (numeric)] cannot coexist: Possible bug
Hi JMP Community,
I am not sure if I came across a bug or a feature in JSL: when I specify in both the "grouped" and "<< Set Data Type ("numeric")" in a call to Col List Box, the "grouped" parameter is ignored.
New Window ("MENU",
	clb = Col List Box (Datatable (dt), all, grouped, <<set data type ("numeric"))
I can see the possible logic of not enabling both when a group contains both Numeric and Character columns, but in my case, the grouped columns are homogeneously set to numeric.
Is there a trick to enable both the "grouped" and the "<< Set Data Type()" parameters is this function?
Best,
TS
Thierry R. Sornasse
Re: JMP > JSL > Col List Box [grouped] + [<< set data type (numeric)] cannot coexist: Possible bug
Didn't manage to get Col List Box working with grouping.
Depending what you want to do, maybe you could use Filter Col Selector?
dt = Open("$SAMPLE_DATA/Probe.jmp");
nw = New Window("MENU",
	H List Box(
		clb = Col List Box(Data Table(dt), all, grouped, <<set data type("numeric")),
		fcs  = Filter Col Selector(Data Table(dt), all, <<character(0))
	H List Box(
