Franck_R
Running Queries Menu bug?
Hi everyone,
I think there is a problem with the "running queries menu" because I want to use this menu to prevent users of my queries from launching them several times queries when they run background.
So I thought I would use the jsl command:
Main Menu ("Running Queries");
That works fine... once!
Yes, because the problem is that once you close this window (manually or in jsl) it never reappears until you restart JMP!
A short video to show the problem with manual launching these window, close then no window anymore:
(view in My Videos)
Is this a bug? Known? Does anyone have a solution or a reset command that I could add to my jsl scripts?
I'm running JMP 15.2.1
Thank you!
Franck
10 REPLIES 10
Franck_R
Re: Running Queries Menu bug?
Great! Thanks!
