dileepkr
Rolling cumulative sum by groups of column entries
I am trying to create the cumulative sum column as shown in the table below.
When I use the Col cumulative sum( value) directly, it gives cumulative sum for entire value column. Can anyone please help me understand how to calculate the cumulative sum for groups of Type as shown in table below?
NameTypevaluecumulative sum
AAAT111
AAAT11011
AAAT13243
AAAT1447
AAAT222
AAAT235
AAAT2510
AAAT2616
BBBT13232
BBBT13466
BBBT1571
BBBT167138
BBBT23434
BBBT23266
BBBT2773
BBBT2881
Re: Rolling cumulative sum by groups of column entries
Use the by capability within the Col Cumulative Sum() function.
col cumulative sum(:value, :Name, :Type);
Use
Tables=>Summarize
Using your m/y column as the grouping column, and nothing else as the statistics column. The result will give you a data table that can be plotted where # Rows is the count of projects for that m/y
dileepkr
Thank you for quick and precise answer :)
pswilliams
Hi txnelson - I'm trying to do a very similar task, however I'm missing something basic.
I have a list of projects with columns for date_start, status, description, etc.
I would like to create a graph demonstrating a cumulative total of "Active" projects, grouped by m/y.  I see this as basically a running count function grouped by date. (starting date format if d/m/y and spans multiple years)
I created the m/y column for grouping, but I haven't been able to graph the count of projects organized by the m/y group. I think I'm missing something basic.
If there is a scripting solution, I will need a guide as to how to input it as I'm not experienced with JSL.
Thanks
Use
Tables=>Summarize
pswilliams
Thanks! This worked perfectly.
