VincentBechard
Best simple way to create stacked separate trend charts (no control chart calculations)?
Vincent Béchard, MASc.
Associate, Analytical Decision Specialist
VincentBechard
Re: Best simple way to create stacked separate trend charts (no control chart calculations)?
Thank you very much @txnelson !!!
This setup gives me exactly what I was looking for :
Just hoping the Overlay charts won't disappear in a future release!
VincentBechard
Since JMP 15, I can't find an easy way to generate many trend charts at once. In older days, I used the "Overlay Charts" which was super fast and convenient. For big datasets, it was the best tool : no control chart calculations, just line plots for all the variables on separate charts. Is there something to replace that capability in JMP 16?
Georg
You can use fit y by x,
it will generate one chart for each x with a few clicks.
Georg
If you go to
     File=>Preferences=>Platforms=>Overlay
you can uncheck the
     Use Graph Builder (default on)
and you will be able to go back to your old version of Overlay Plot
You can also stack your columns, and then use the "Dialog" button on the Graph Builder window, to use a traditional dialog box and specify a By column to get a separate graph for each of the stacked columns.
VincentBechard
