EOwl
Return the Name of a referenced column
I'm writing a helper function that renames the a column group if it contains a particular column name.
dt = Open( "$SAMPLE_DATA/Cities.jmp" );
/*//Use if already existing
dt = Data Table ("Cities");
dt << group columns( "xy", {:X, :y} );
dt << group columns( "pollutants", :Ozone :: :Lead );
match_col = "X";
new_name = "coordinates";
groups_list = dt << get column groups names;
show(groups_list);
For Each({grp, ig}, groups_list,
	cols = dt << get column group( grp );
	show(cols);
	For Each ({column, ic}, cols,
		show(column);
		colname = column << Get Name;
		If(colname == match_col,
			try(dt << rename column group( grp, new_name );)
This works fine with basic grouped columns, but falls over if there's an inherited group from a Link Reference:
dt_state = Open( "$SAMPLE_DATA/State Abbreviations.jmp" );
//Need more than 1 column
dt_state << New Column( "Dummy", Numeric, "Continuous", Format( "Best", 12 ));
//Link Tables
dt_state:Abbreviations << Set Property( "Link ID", 1 );
dt:State << Set Property("Link Reference", Reference Table(dt_state));
dt_state = Data Table( "State Abbreviations" );
match_col = "X";
show(groups_list);
	show(cols);
		show(column);
Firstly, the << Get Name function errors on :Ozone, which worked fine in the simpler example.
Even if that error is resolved, the linked column looks different in the Log:
column = :Y;
column = Referenced Column("U.S. States[State]", Reference(Column(:State), Reference(Column(:U.S. States))));
How do extract the text name? i.e "U.S. States[State]"
Re: Return the Name of a referenced column
Most likely you are running into issues as JMP is referring to wrong data table. My suggestion is to ALWAYS use explicit column references -> convert your column (references) always to strings and then use different formats as needed. In your case something like this
dt = Open("$SAMPLE_DATA/Cities.jmp");
dt_state = Open("$SAMPLE_DATA/State Abbreviations.jmp");
dt_state << New Column("Dummy", Numeric, "Continuous", Format("Best", 12));
dt_state:Abbreviations << Set Property("Link ID", 1);
dt << group columns("xy", {:X, :y});
dt << group columns("pollutants", :Ozone :: :Lead);
match_col = "X";
	cols = Transform Each({colweirdness}, dt << get column group(grp), AsColumn(dt, colweirdness) << get name);
	For Each({colname, ic}, cols,
			try(dt << rename column group(grp, new_name));
match_col = "X";
