tom_abramov
Resizing Data Box
Is there a way to fix/resize by user the size of the data box?
Currently the size of the box is set automatically due to the objects in the window.
New Window("A",
	H List Box(
		V List Box(dt << New Data Box(), obj = dt << Bivariate(Y(:Weight), X(:Height))),
		Spacer Box(<<size(30, 0))
Re: Resizing Data Box
If that scroll box option isn't what you want, then you can try directly resizing the DataBrowserBox (disable auto stretching)
nw = New Window("A",
	H List Box(
		V List Box(
			db = dt << New Data Box(),
wait(2); // demo purposes
db << Set Auto Stretching({0, 0});
db << Set Width(300);
db << Set Height(200);
11 REPLIES 11
The window size can be changed by passing the Set Window Size message to the New Window
Names Default to Here( 1 );
nw = New Window( "A",
	H List Box(
		V List Box(
			obj = dt <<
			Bivariate( Y( :Weight ), X( :Height ) )
		Spacer Box( <<size( 30, 0 ) )
nw << set window size( 600, 800 );
P.S.  Please use the JSL icon at the top of the Preview Window to enter JSL.  It provides the user with an easier form of the code to read and understand.
tom_abramov
Thank you,
I am aware of this solution.
However, I have a full-screen dashboard with a data box inside, meaning the main window is fixed in size (full-screen). I would like to adjust the size of the data box independently of the parent window.
I am not aware of a reliable way to do that.  Others more experienced in creating Dashboards may have an answer.
You can for example place the data box inside Scroll Box
	H List Box(
		V List Box(
			Scroll Box(size(100, 100), dt << New Data Box()),
nw << set window size(600, 800);
Level XI
makes the data view smaller, but definitely no fun to work with 2 stacked scroll bars ...
tom_abramov
Thank  you,
Tried this solution as well
Resizing scroll box does not resize the data box.
	H List Box(
		V List Box(
Level XI
the minimum height is given by the side panel, so maybe close it?
- and reduce the size of the header:
db << close side panels( 1 ) << close summary panels( 1 ) << Set Header Height( 20 );
tom_abramov
Thanks! Was looking for "close side panels". Very helpful.
