shampton82
Reset selection button on global filter
hey everyone, I was wondering if anyone knew a way to use JSL to recreate the action of pressing this button
I looked in the scripting index and didn't see anything that appears to related to this function.
Thanks for any guidance!
Steve
Re: Reset selection button on global filter
There might be better options, but you can look for the button and then click it with a script
dt = Open("$SAMPLE_DATA/Cities.jmp");
nw = New Window("",df = dt << Data Filter(
	Location({379, 384}),
	Mode(Include(1)),
	Add Filter(
		columns(:Region, :POP),
		Where(:Region == "MW"),
		Display(:Region, N Items(6))
dt << Select Rows([1]);
btn = (nw << XPath("//ButtonBox[@title = 'Reset selection']"));
btn << click(1);
hogi
Level XIII
Any update of the data filter will give back the control.
you could trigger an update which doesn't change the selection, like
df <<Inverse(0)
[if it was inverse(1) before, use Inverse(1)]
