kuanaunwei
Replacing a blank row with another row data with an if statement
I have an original set of data (table1), and I am trying to script it to the result in table 2.
If any number that is below 300, will print "type1" string into "result1" column.
If any number is above 300, will print "type2" string into "result2" column.
Number type1 type2 result1 result2
100 a1 a2
200 b1 b2
150 c1 c2
275 d1 d2
555 e1 e2
424 f1 f2
572 g1 g2
783 h1 h2
125 i1 i2
Table1: Original data
100 a1 a2 a1
200 b1 b2 b1
150 c1 c2 c1
275 d1 d2 d1
555 e1 e2   e2
424 f1 f2   f2
572 g1 g2   g2
783 h1 h2   h2
125 i1 i2 i1
Table2: Result
So far, what i have done on my script is shown below.
dt = Current Data Table();
dt << New Column("result1",
	Character,
	"Nominal",
	For Each Row(If(:Number << 300), :result1 == :type1, "")
dt << New Column("result2",
	Character,
	"Nominal",
	For Each Row(If(:Number >> 300), :result2 == :type2, "")
Re: Replacing a blank row with another row data with an if statement
There are couple of issues, using >>/<< as comparison and using For Each Row inside column creation. Below is one option for working syntax using << Set Each Value (do not that if value is is exactly 300 it will be empty)
dt = New Table("Untitled",
	Add Rows(9),
	Compress File When Saved(1),
	New Column("Number", Numeric, "Nominal", Format("Best", 9), Set Values([100, 200, 150, 275, 555, 424, 572, 783, 125])),
	New Column("type1", Character(16), "Nominal", Set Values({"a1", "b1", "c1", "d1", "e1", "f1", "g1", "h1", "i1"})),
	New Column("type2", Character(16), "Nominal", Set Values({"a2", "b2", "c2", "d2", "e2", "f2", "g2", "h2", "i2"}))
dt << New Column("result1", Character, "Nominal", << Set Each Value(
	If(:Number < 300,
		:type1
	,  //else
dt << New Column("result2", Character, Nominal, << Set Each Value(
	If(:Number > 300,
		:type2
	,  //else
I strongly suggest checking out scripting index directly from JMP's Help menu and Scripting Guide from JMP Help Page .  There are also other scripting sources such as
Introduction to the JMP Scripting Language to get to know the syntax
	Add Rows(9),
	If(:Number < 300,
		:type1
	,  //else
	If(:Number > 300,
		:type2
	,  //else
kuanaunwei
Hi jthi, Alright will tryout on the help info. The script works. Thanks for the help.
I personally find that approaching issues like this using an Excel like approach, where the new columns are created with individual formulas applied to each column is confusing and inefficient.  JMP's capability to directly modify data table values in "open" JSL code can be used to solve the problem in a cleaner and more efficient manner.
// Create the new columns
dt << New Column( "result1", Character );
dt << New Column( "result2", Character );
// Populate the columns
For Each Row( If( :Number < 300, :result1 = :type1, :result2 = :type1 ) );
