Jackie_
Replace characters in the string
Hi JMP community,
I'm trying to write a jsl code that would take a column with a string in it, and in each row, replace the count with the values in the count column. The final results should look something like in the Results column
Any Suggestions?
Craige_Hales
Re: Replace characters in the string
The strings appear to follow the same pattern. Maybe use the words() function with either a space or " as the separator. Then use concatitems() to put it back together.
Craige
I think the issue is with this line
x[4] = Char( arra[binxx[j]] );
I would modify the loop to loop over the rows instead of associative array + rows:
dt = Current Data Table();
/// Get list of all the bins
binxx = Associative Array(:Bins[23 :: N Rows(dt)]) << Get Keys;
delcols = {"", "	", "}"};
/// Remove garbage values
For(i = 1, i <= N Items(delcols), i++,
	Remove From(binxx, As List(Loc(binxx, delcols[i])));
///Get rows where Bins column contains BIN =
rows = dt << get rows where(Contains(:Bins, "BIN = "));
total = {};
//Loop to calculate the count of each bins
For(i = 1, i <= N Items(binxx), i++,
	Insert Into(total, N Items(dt << get rows where(:Bins == binxx[i])))
//create array to store bin and counts
arra = Associative Array(binxx, total);
//loop to modify the character count in the table
For(i = 1, i <= N Items(rows), i++,
	x = Words(:Bins[rows[i]]);
	curbin = Substitute(x[3], "\!"", "");
	If(Contains(arra, curbin),
		x[4] = Char(arra[curbin]);
		:Bins[rows[i]] = Concat Items(x);
		continue();
6 REPLIES 6
Craige_Hales
Craige
Regex is one other option
Regex(:Results, "(BIN = \!".+\!") (\d+)(\!".+)", "\1 " || Char(:Count) || "\3")
but in this case I would use Words() + Concat Items() like Craige suggested (if the pattern is always same)
Jackie_
Thanks Craig and Jarmo
Jackie_
@jthi
I used Cragis logic to update the count in the string but it doesn't replaces the correct count string. I'm not sure what I am doing wrong. Can you take a look at my code?
Assigns incorrect counts
Here's the code:
binxx = Associative Array( :Bins[23:: N Rows( dt )] ) << Get Keys;
For( i = 1, i <= N Items( delcols ), i++,
	Remove From( binxx, As List( Loc( binxx, delcols[i] ) ) );
rows = dt << get rows where( Contains( :Bins, "BIN = " ) );
total = {};
For( i = 1, i <= N Items( binxx ), i++,
	Insert Into( total, N Items( dt << get rows where( :Bins == binxx[i] ) ) )
arra = Associative Array( binxx, total );
For( j = 1, j <= N Items( binxx ), j++,
	For( i = 2, i <= N Items( rows ), i++,
		If( Contains( arra, Substr( :Bins[i], 8, 1 ) ),
			x = Words( :Bins[rows[i]] );
			:Bins[rows[i]] = Concat Items( x );
total = {};
		continue();
Jackie_
Thanks a lot Jarmo
