Is there any better way to replace the cell values?
Here is what I tried
cols = dt << get column group( "Tests" );
get_cell_color = Function( {col, r},
s = col << get script;
//Locate argument "Color Cells" in column script
For( i = 1, i <= N Arg( s ), i++,
If( Head Name( Arg( s, i ) ) == "Color Cells",
p = i;
Break();
//Identify the sublist that contains the color of row r
L = Arg( Arg( s, p ), 1 );
For( i = 1, N Items( L ), i++,
If( N Row( Loc( L[i][2], r ) ) == 1,
color = L[i][1];
Break();
color;
test_cols = Transform Each( {col}, cols, col << get name );
dt << Select All Rows;
selrow = dt << get Selected Rows();
dt << begin data update;
For Each( {testcol, idx}, test_cols,
For Each( {ro, idx2}, selrow,
cellcolor = get_cell_color( Column( testcol ), ro );
If( !cellcolor == 3,
Column( testcol )[ro] = 0
dt << end data update;
