meredith
Repeated measures ANOVA using JMP
when I perform a full factorial repeated measures anova in jmp the output gives me a warning:there are linear dependencies among the input columns. what does this mean? the output doesn't show any p value. JMP Pro
Re: Repeated measures ANOVA using JMP
The Singularity Details report indicates that you have terms in the model for effects that are confounded. Linear regression is unable to estimate parameters for these terms.
Please see this JMP Technical Note to check how your data should be organized in the data table and to check how you specified your model.
