k_bott
Repeated measures ANOVA in JMP
Greetings -
We'd like to add a repeated measures ANOVA to the analyses that our introductory bio students use. I've found two examples via JMP (help manual within JMP 10, attached,re and also the JMP website, here: http://www.jmp.com/support/notes/30/584.html) -- which each seem to go about this in a different way (in terms of process).
So - wondering what method other users choose for repeated measures ANOVA. (Our students will be doing a basic crossover design - e.g. take three treatments and apply to the same 9 plants.)
Thanks -
-kristin
jules
Re: Repeated measures ANOVA in JMP
Hi K.Bott,
I realize this post is a few years old, but if you (or others) are still looking for an easy way to add repeated measures ANOVA to your course (one-way, or factorial) I just posted a repeated measures ANOVA add-in to simplify the process. You can find the add-in here:
Full Factorial Repeated Measures ANOVA Add-In
I hope this helps,
julian
jules
Hi K.Bott,
I hope this helps,
julian
LeoDurante
Hello Julian, thanks for this post, it helped me a lot. I was just wondering how you would report those results for a two-way repeated measurements ANOVA, what kind of number would your report for SSerror for example?
Cheers,
Leo.
