Repeated Single Factor Anova
I tried to do the one way anova for EC level affect the data result. However, whenI use the Fit X, Y model. It always shows as Bivariate fit model when I want it one way anova model.
Would you please help me with this question? I have also attached my jmp sheet here
Re: Repeated Single Factor Anova
Make your EC level column have the nominal or ordinal modeling type. Then use Fit Y by X and you will get ANOVA rather than regression.
Dan Obermiller
