vishwasanj
Repeat a sequence in a column -JSL
I was looking into the scripting guide, and it talks about Sequence( from, to, stepsize, repeat ); with from, to , stepsize and repeat.
What if I want 3 values say, 1, 50000, 100000 repeated till the end of table in a column? (This is basically highlighting the 3 values in a column and right click and say fill to the end of the table)
Do i have to run a for loop, or is there like a one line script available in JSL?
Thank you so much for your suggestions.
David_Burnham
Re: Repeat a sequence in a column -JSL
Here is some code to play with
lst = {1,50000,100000};
nRepeats = 10;
values = Repeat(lst,nRepeats); // this will be a list of 30 values
values[1::NRows(dt);
Column(dt,"Test") << Set Values(values);
// if the table only had 25 rows I could use values[1::25]
-Dave
Notice that when you select Cols > New Column, there is an option near the bottom of the dialog to initialize the new column in several ways including a sequence. If you created the new column by double-clicking to the right of the last column, then select the new, empty column and select Cols > Column Info to see the same feature.
Note that this feature disappears as soon as you enter any values in the column another way.
No formula or script necessary for a simple case like this one. Already provdided for,
PS_Ato
Hi Mark,
this was new for me - thank you. Could you please help me how to create a script? We import data regularily and always need to add columns with e.g. 10 repetitions each value (from 1 to 16).
David_Burnham
nRepeats = 10;
-Dave
