tupdegrove
Rename Graph in Project
JMP Pro 16. I'd like to rename those 7 graphs in a project. How?
Can they be reordered?
Re: Rename Graph in Project
Go to the Tab for the graph output, and double click on the tab's title.  You will then be able to change the name of the tab, which will change the name of the Workspace entry
tupdegrove
Works great. Thank you.
Can the Workspace entries be re-arranged? In the Workspace, doesn't like you can drag them. However, they can be dragged (drug) on the tab row to different dock areas (top, right, middle) but when in the middle dock area, you can't seem to order them (from left to right).
